Furisode Right Sleeve goes crazy
Peter WadePeter Wade Posts: 1,677
I've come across a strange effect on the right sleeve of the Furisode for Genesis and I wondered if anyone else has seen this, or if it is a problem with my setup.
With the Fursisode main part conformed to Genesis, If I move Genesis along the x-axis the right sleeve bends sideways. The left sleeve isn't affected and moves along the y and z axis do not do anything like this.
After moving Genesis the Left-Right values are changed on the sleeve sections, they were all zero before. Setting each one back to zero makes the sleeve hang as before but using the Zero Figure option in the parameters menu has no effect.
I just found that if I move Genesis by selecting the hip instead of the body this does not happen. It also does not happen with the Genesis 2 version, only Genesis 1.
It isn't really a problem as long as I remember to move Genesis from the hip only, but it is very odd.
I am attaching a render of this with a basic Genesis, no morphs and no posing adjustments on Genesis or the Furisode.
    edited October 2013
    I'm preparing an update to fix it. Meantime, you can move Genesis the regular way; just afterward, select all of the bones in the right sleeve and set "Left-Right" to 0.
    EDIT: I mean set the left-right to 0. It's tied to the x translate inappropriately. I've uploaded a fix and the DAZ testing staff will have the update for everyone as soon as they can.
    Post edited by SickleYield on
  • KatteyKattey Posts: 2,899
    Can you share why it happening, SickleYield, and how to fix it? I had that problem once too and ended up redoing the whole rigging from scratch.
    In this specific case I accidentally froze the ERC of the left-right parameter on the sleeves to the x-translate value. I went to each individual sleeve bone in the Property Hierarchy tab and deleted the Control property that was causing the issue.
    edited October 2013
    Oh, it might explain things, - back then I didn't know what exactly ERC was doing. Thanks! Hope to catch update shortly.
    Post edited by Kattey on
