what is ground and how to align objects above ground
daveso
as you can see from these screenshots, it appears the wagon and props are actually below the ground level
when I render, it appears they are rasied above the ground a bit. I tried lowering each one using Y Tanslate, but that did not seem to work
Then I tried setting the field ground to move down ... when I did that, it buried the wagon and props. I raised them and found I had the same problem again.
Not really sure why this is happening or how to fix it.
any ideas?
Post edited by Chohole on
Try setting Ground Position to Manual.
Have you tried moving the objects "to floor"? (Crtl+D)
Laurie
Unless he positions the Apple Orchard set so the ground of the set is at 0, moving the object to floor will lift them even higher.
@daveso, Try this:
Do a test or spot render. If the props still aren't touching the ground, you can move the plane down incrementally until they do.
yes..that reulted in the underground deal ... after the cart i did the crate, etc ... stuck in the mud.
thanks..will give it a try. I ended up also to note the ground line by using the front camera ... moved everything around to meet it ..seemed to work ok ..got a little low but looks pretty much like the wheels are stuck in the dirt.
@daveso, Another problem you're running into is the area you're using has very uneven ground. This is a viewport draw in Shaded Wireframe mode:
You may be able to flatten the area out using a dForm, Influence: Weight Map. Let me know if I can help with that.
Alternately, you could change the angles of the crate and waggon so that they fit to the uneven ground. That one's pretty time consuming, but looks realistic.
In this situation, you have your own ground plane so you don't need/want IRay to draw the ground at all. Click the button in the render settings under "draw ground" to turn it off. Then you just have to make sure all your objects are touching the ground of your set in the proper way, and the shadows will cast as expected.
