Problem with figures
Hi, I have problem with figures. Auto-fit: g8 female eyelashes. What should I do?
  • L'AdairL'Adair Posts: 9,479
    Is this happening when you load the character?
    Is it with this specific character, Murielle, or with all Genesis 8 females?
    Were the affected figures working previously and now do not?
  • Richard HaseltineRichard Haseltine Posts: 108,465
    For some reason it's lost either the identity of the Genesis 8 Figure or the compatibility of the lashes - if you just cancel that dialogue and try loading a set of Genesis 8 Female clothing does that too throw up the AutoFit dilalogue?
  • rocker-soulrocker-soul Posts: 3
    edited April 2019
    it's with all G8 females characters. I have already reloaded G8, but the problem is still there. The path is correct. I have changed the path to My Library and reinstalled Daz.
    Post edited by rocker-soul on
  • For some reason it's lost either the identity of the Genesis 8 Figure or the compatibility of the lashes - if you just cancel that dialogue and try loading a set of Genesis 8 Female clothing does that too throw up the AutoFit dilalogue?
    it"s not for clothing. For all G8 characters
    1369 x 763 - 473K
    That blocky look is what happens when Daz can't find certain files. Let's take a look at your Content Directory Manager. To get there, go to Preferences in the Edit menu, (or F2). In the popup dialog, click on the Content tab, across the top. Find the Content Directory Manager… button toward the bottom and click on that. The resulting popup dialog will be the Content Directory Manager. Expand all of the Content Sets and then screenshot that dialog.
    In case you need the help, this image shows the progression of dialog popups. Click on the image to open the full-size image in a new window/tab if the text is hard to read here.
    (Note: This is a compilation of screenshots, not what your screen will look like.)
    Also, do you install via DIM or Daz Connect?
    Well, as L'Adair says it does look like an issue with the content. But I was asking about clothing as that is an easy way to find fitted items - the lashes are also a fitted item, and the dialogue you were getting relates to that process going wrong.
