Dazstudio 32 bit vs 64 bit
I was wondering what the difference is in the bit versions. Is 64 bit more reliable, say for example - 3delight rendering and stability?
64 bits version can use more system resources (more RAM, mainly) so it can handle bigger scenes.
32 bits version is still useful as a few features like LipSync only have a 32 bits version.
You can have both versions installed on a 64 bits system.
Iray is available only in the 64 bit version
LipSync is in only the 32 bit version.
Oh, right, I forgot about that...
The other day I've verified that Daz was using 15Gb of RAM...so, unless you need that LipSync, you should go for the 64-bit version! :D
