Auto Shape Enhancer [Commercial]
24
  • takezo_3001takezo_3001 Posts: 2,027
    DMaster said:
    Can anyone post some bend/side ASE glute morphs for takezo_3001
    Thank You
    I already bought it, so I can do them myself thanks...
  • DMasterDMaster Posts: 410
    Thank you takero_3001
    edited April 2019
    This product is awesome, but I'm running into a werid problem with it. With some poses, the Shoulder enhancer affects the  left eye on G8M. It isn't every pose so I've been having trouble figuring out why it happens  but it seems to make the left eye go sideways. This can't be corrected by zeroing the eye.
    1. For example, load Base male.
    2. Make sure shoulder enhancer is on.
    2. Load Bold pose number 20 https://www.daz3d.com/bold-poses-and-expressions-for-nix-8-and-genesis-8-male
    3. Left eye goes out of alignment.
    It doesn't happen with all poses, so its tough to trace why this is happening. On some poses it doesn't go too far to the left, so its hardly noticble... Others it goes way left so it very much is.
    1003 x 654 - 95K
    I believe it is this one: MD_JCM_L ArmPit Fix01  that is causing the eye issue, but only when the upper body is bent enough to trigger it significantly does it show..   The right one doesn't have this issue.
    Serene Night I have fixed the MD_JCM_L ArmPit Fix01. Unzip and replace the MD_JCM_L ArmPit Fix01.dsf
    Thank You. Will send in an update later next week.
    zip
    zip
    Auto shape Male MD_JCM_L ArmPit Fix01.zip
    5K
    edited April 2019
    DMaster. Thanks for this. It seems to be working properly without he eye crossing. Thanks for the quick fix.smiley
  • Leonides02Leonides02 Posts: 1,379
    Thanks so much for this product! Are the seperate abdominal morphs in the update, or do we need to download them manually? smiley
    Leonides02. Just download from the above zip from Posts: 30
    I will send in update latter on 2 to 3 weeks. A bit busy working on the Auto Face Enhancer.
    Thank you
    Hi all. If you boys and girls like the product. Please help by spreading the words and post your works. I would like to do this fulltime with more support. Thank you all for purchasing the products.
  • odconstantodconstant Posts: 2
    edited August 2019
    Whenever I dial the shoulder enhancer, it moves the left eye sideways.
    Thank you.
    My dum-dumb head did not read about the fix.
    Thank you again!
    Post edited by odconstant on
  • MoreTNMoreTN Posts: 340
    Thinking about getting these. What are peoples' experiences, please? I see Serene Night seems to like it, so that's a good sign, but any other users want to comment?
    They're good and add a good bit of realism. You may need to adjust the dials manually, but that's half the fun!
  • nonesuch00nonesuch00 Posts: 18,763
    Well I bought the G8F version already out but actually haven't tried to use it. I'm waiting for the G8F 2nd version & the G8M version before I use them as I've never liked using geoshells.
  • vwranglervwrangler Posts: 4,975
    The G8M version of Auto Shape Enhancer has been out for a while. It's not a geoshell product.
    I mistook the acronym for AFE, auto-face-enhancer for G8F. Sorry to the OP. I didn't buy this ASE product.
  • plasma_ringplasma_ring Posts: 1,027
    I have both G8M and G8F and use them all the time. I tweak the dials depending on character and pose, and mostly use it close to full strength on characters who are supposed to be wiry or muscular.
    Just a collection of the update for Auto Shape Enhancer.  Ahead in order to work with the Auto Muscle Enhancer.
    1-fix male eye movement on one of the JCM morphs
    2-add abs control for male and female
    small fix that was needed.
    Thank you all who have purchased the product legally. Your support help.
    zip
    zip
    Auto Shape Enhancer Update.zip
    31K
    I haven't bought this product but might after AME is released. Will your update there be included into the store bought product. I need to see more renders of AME before I buy AME or ASE as I can't test either not having purchased.
    edited April 2020
    Yes. It is best if you know what you are buying. The update for ASE, it is best if you download it here. I will update the ASE with a bit more features, thus the wait for me to re-submit.
    Post edited by DMaster on
  • inquireinquire Posts: 2,435
    edited April 2020
    Are we supposed to download and install this Auto Shape Enhancer Attachment file, or will the correction show up in the DIM as a Product Update?
    Post edited by inquire on
    edited April 2020
    extract the zip file and put it in your Daz3d Lib folder. So put all file into you (Daz3d LIB)>data
    If you don't know how to do this. then please don't do this. Wait for the update.
    Well, since the DIM can only uninstall what it installs, I think I'll wait for the update. Not that I want to uninstall the product, you understand. It's just to keep all of the items together. But I'm looking forward to the update being posted in the DIM.
  • QuasarQuasar Posts: 681
    Just noticed the shape enhancers in Fast Grab.
  • barbultbarbult Posts: 26,292
    @DMaster, Is the master controller supposed to control the new Abs morph? It doesn't.
    edited April 2020
    Yes, It should. It was an ad-on for you to adjust hidden abs muscle showing or not showing. I like the muscle showing. Some people may need not have it. So I created one for a quick request.
    I will set up an update next week. and put it here.  both male/female. It is a very small fix. I don't want to trouble DAZ to go about testing and uploading the DIM. Unless I plan to update it even more. Thinking about it. I will put in some HD wrinkles as a teaser to my Auto Wrinkle Enhancer HD. This way we can have a real update to ASE for DIM install.
    I will put some wrinkles in the arm, knee and add an HD Rib Cage for the update next week.
    Thank you.
  • SigurdSigurd Posts: 1,094
    Wow! Great support!
    edited April 2020
    Here is the update to ASE G8Female.
    I will send it to Daz this Weds. If anyone can help with some new promo images. I would love to use them. Just upload it here.
    The Update has small skin wrinkle on the arms, elbow, hip, and knee. Some more corrective morphs along with new Abs slider. Now work with the ASE Master. Turn on SubD_3 to see the small wrinkles.
    I also did a rib cage with hip bones - in SubD 3 to see = bend the chest back
    https://www.dropbox.com/sh/970fkxevrsqtk60/AACfrMb9WyQqqjoIl6oQm9XEa?dl=0
    856 x 1000 - 250K
    Wow! And thanks!
  • DaventakiDaventaki Posts: 1,624
    ASE dials cranked to 100 except for the ribs it was at about 50%.. Second image is with ASE turned off for comparison.  Will see if I can get some decent shots of the new wrinkles
    1000 x 1000 - 977K
    1000 x 1000 - 2M
