equalize facets
Is there a way to equalize the spacing of facets along a face in Hexagon? After moving points and edges some of my facets are not square anymore. Is there a command in Hexagon that will move the facet points so that each point will be the same length from each other along while keeping close to it's same shape? Basically align up all of the facets along a surface.
No. You can try carefully using the softening brush.
You have an image of your mesh to post?
