Forest
VitachickVitachick Posts: 135
by
Andrey Pestryakov
Also have Forest Superior..
For some reason Forest figure is not showing.
Help..How do I contact vendor?
  • LindseyLindsey Posts: 2,009
    edited October 2013
    If I have an issue with a product, I'll hit up the DAZ Customer Service first, but you can send Andrey Pestryakov a private mail
    The picture below shows the default location where the Forest and Forest Superior Scene files are supposed to be in the DAZ Studio Formats library. "DIM My Library" will be named differently in your DAZ Studio.
    971 x 607 - 57K
    Post edited by Lindsey on
  • VitachickVitachick Posts: 135
    Thank you! Guess only works with 64 bit comp? Using my Win XP 32 bit and it crashes
    instantly...
    The set is huge and takes a lot of RAM. Post your computer's installed RAM and I'm sure somebody who's used it on a 32-bit system with the same RAM installed can give you tips on using it if they have it. Worse case scenario, if you bought it within 30 days you can return it.
  • JaderailJaderail Posts: 0
    A 32 bit PC can only see 4gb of ram, the Forest needs most of that to just load. As Said it is HUGE and it used to have a WARNING in the Info on the product page. That needs to be returned to the Info so users know what to expect.
    Too late to return as purchased back in June. I do have win7 64 bit computer
    also. Installed Daz 4.6.. Will see what happens.
    Why would someone make something that hugh anyway?
    Thanks all for replies..
