Supersuit in Carrara?
I can load genesis and apply the supersuit but I can't find how to adjust the suit. Is this possible in Carrara 8.5?
works better in DS .
But can it be adjusted in Carrara?
yes - click actor - look under parameters
Found it thanks!
What about the colors, can't figure out how to adjust them now.
How is the color channel set in the suit's shader?
(Looking at the supersuit bundle now. If it's really that alien to Carrara, it may not be worth it.)
I know that the shaders for the Supersuit are created specifically for DS, I haven't tried them.
Found it thanks!
the only way I know that works is to do it in DS and save as DUF ( that will work for sure )
you welcome
here's one from C8.5
Looks good bigh, thanks for the info.
you welcome
more info -
ok - after you have your DUF in C .
you can goto Browser
Products - S
find Supersuit
you can play with it by clicking on the suits things - ( but have to get the texture from DS first )
I'm still not doing something right. Saved as .DUF but when I opened it in Carrara all I had was an empty suit. Dragged it to actor but it didn't fit to genesis.
OK, I saved it as a scene and it worked. When I saved it as a character preset it was the empty suit.
I used eyeGore for Genisis with the super suit in DS and saved the scene then opened in Carrara and posed and added the other bits
Seems ok.. I haven't really used the super suit since I bought it so was a good practice to find out.
Looks good!
I'm starting to make a little progress.
neat :-)
HELP Me
