Problem with uv sets
Hi
I am trying to package a set for the Daz Studio. I have not packaged any geometry before.
I am getting this error message:
The directory 'C:/ProductTesting/People/Genesis 8 Female/Clothing/lululee/G3-G8-Babs/IRAY/BA-Geometry/Babs-ShoulderGaurds.duf//data/lululee/Babs/Babs-ShoulderGaurds/UV%20Sets/lululee/Base/' does not exist!
I saved the the Shoulder gaurds as "Support Asset" "figure/propsAssets"  also "morph assets"
I also originally save it as uv assets. When I got that notice that they did not exist I deleted the uv assets and resaved the above above assets without the uv assets.
I did not at any point save any uv templates as I have no clue if I need to.
Any help will be greatly appreciated as I am totally befuddled at this point.
Cheerio
lululee
  • Richard HaseltineRichard Haseltine Posts: 111,715
    Is that the full text of the error, including the // in the middle?
    When you save DS native files, geometry and uv info is written to the Data folder section.  You need to go into your Data folders and copy the product files from there to your working directory.  IF you dont, no one will be able to use the product.
  • lululee1lululee1 Posts: 346
    Hi Richard,
     Yes, that is the exact copy and paste from the content checker software.
    Should it only be 1 /  ?
    Cheerio
    lululee
    Thanks Mattymanx for your valuable info.
    Cheerio
    lululee
    Hi Richard,
    Cheerio
    lululee
    Yes, the two consecutive folder separators does look off. Please post a screen shot of the error, to remove any confusion due to special characters or the like.
    Hi Richard,
      Thanks so much for your help.
    I had 415 of those two consecutive folder separators . Thanks to you I was able to locate them and do batch fix.
    You definitely saved ny day.
    Hope your day rocks.
    Cheerio
    lululee
    I'm glad my vague maunderings pointed you in the right direction :)
