Udane hair invisible in mirrored surface
areg5
Here is an odd one: I have been using mirrored surfaces for some time now, and one of my genesis models has udanehair. The hair doesn't show up in the mirror. Also doesn't work for Paxton hair. The mirror works fine for everything else and other kinds of hair.
Post edited by areg5 on
Select the hair, go to the Surfaces tab, and make sure Raytrace is ON. I think it's set to OFF by default for that hair, if I recall correctly.
Do you mean to choose raytrace under "reflection mode?" I did that. Didn't work.
never mind. I got it. Thanks!
