Need advice on render settings
RAMWolffRAMWolff Posts: 10,369
Hi,
Not looking to use any of the advanced settings just simple render settings. I can't get body hair mapps to look crisp enough. I know there are settings that will get more detail out of a map but I can't seem to remember how to do it. Right now every attempt is coming out blurry!
HELP
  • RAMWolffRAMWolff Posts: 10,369
    HAHAHA.... I figured it out. Here are my settings. I saved the render settings out as something that can be applied to a scene with need of allot of detail being brought out like body hair.
    692 x 895 - 103K
    Turn the shading rate down to 0.1 even if you can afford the time. IIRC pixel samples are the other main thing that affects what you're looking for. I have them at 12 normally.
  • Collective3dCollective3d Posts: 446
    Shading rate and pixel samples definitely give me the most bang for the buck. Just be really careful with raytrace depth unless you want to be rendering all day :)
    Thanks folks. I might tweak it a bit more but pretty happy with what I came up with. I have a fast system so it's OK for ME. I will put a warning about shading rate and pixel samples in the ReadMe when the time comes.
  • Jim_1831252Jim_1831252 Posts: 728
    Isn't that pixel filter width a bit high? I thought 6, 6 was the optimum for sinc. Also wondering if you're using the 4 raytrace depth. Unless you're rendering lots of reflection bounces there isn't much need for more than 1 (in most cases I can think of). Sorry I know you weren't asking about those lol
    I also agree that increasing pixel samples will help. Try for 12 and see if you notice much difference.
