issue with newgen script(SOLVED)
TheKD
So earlier this weeks, I had to reinstall windows 7 again, so had to also install DS again naturally. I did not have to reinstall my content, because that is on a seperate hard drive from the OS. Today I fired it up to do some renders, a script to load and it will not work.
This is what comes up in the log:
2019-03-30 13:44:45.081 Loading script: E:/G8F/People/Genesis 8 Female/Anatomy/!!New Genitalia For Victoria 8/New Genitalia For Victoria 8.dsa
2019-03-30 13:44:50.045 Script executed successfully: E:/G8F/People/Genesis 8 Female/Anatomy/!!New Genitalia For Victoria 8/New Genitalia For Victoria 8.dsa
2019-03-30 13:45:39.806 Loading script: E:/G8F/People/Genesis 8 Female/Anatomy/!!New Genitalia For Victoria 8/New Genitalia For Victoria 8.dsa
2019-03-30 13:45:42.716 Script executed successfully: E:/G8F/People/Genesis 8 Female/Anatomy/!!New Genitalia For Victoria 8/New Genitalia For Victoria 8.dsa
2019-03-30 13:45:45.854 WARNING: QAccessibleWidget::rect: This implementation does not support subelements! (ID 8 unknown for DzActionMgr)
Not sure how to troubleshoot this one.
I came up with what sounded like a dumb idea to me, and just drag and dropped the script and associated files exactly where I had them already. It worked for an unkown reason. If anyone else has the issue with reinstalling OS and or daz studio, and a script in your library that hasn't changed at all not working, try a reinstall lol
Nothing to worry about.
"WARNING: QAccessibleWidget::rect: This implementation does not support subelements! (ID 8 unknown for DzActionMgr)"
Looks like someone written a script that you executed and there is some interface element "Widget" that don't understand how to interpret some script line telling the script interface how it should look like.
The script is supposed to load in a geographed genital prop that matches the skin tone of the genesis 8 figure, it fails to do so now. Those ID unkown errors are the only thing that shows in the log. It's weird as it used to work before fine, in both 4.10 and the beta. If I remapped all the unchanged libraries back in, I would expect all the scripts to work like they used to.
