The Woolyloach Come Home Complaint Thread
1323335373850
  • kyoto kidkyoto kid Posts: 41,969
    ..yeah, the memory stick issue was one. I'll try reseating the GPU after I shut the system down. Hopefully it is something that simple again.
    almost november. rdna should be having their sale. can't remember if alphaseed goes on sale too. fantasy drops hair looks interesting.
    Rezca said:
    Rezca said:
    Did some tweaking on the Vue scene...
    looks nice, perfect lonely dragon terrain.
    leetlest dragon
    WE ARE HOLDING SPYRO TO RANSOM
    Post some thing in reply to me or you will only get him back one piece at a time!!
    whatssacominnago ?
  • starionwolfstarionwolf Posts: 3,670
    edited October 2013
    Sisca said:
    Either way if you commonly shut off your machine at night, especially if you do so shortly after completing a render, you might want to try re-seating the video card.
    Any time you allow the machine to heat and cool you get expansion/contraction which can cause things to work loose. You might want to double check the seating of other components while you're in there.
    people shut off their computer at night? i shut mine of after lunch.
    here was my routine last Thursday:
    finish eating lunch
    turn off computer to put new hard drive in.
    turn on computer and clone old data to new drive.
    turn off computer and disconnect old drive.
    turn on computer and test new drive.
    eat dinner
    notice that DVD drive isn't working
    turn off computer
    reseat IDE and Molex power connector to DVD drive
    turn on computer
    try to boot from recovery partition on new drive
    computer won't boot correctly
    Turn off computer
    go to bed
    use new computer without recovery partition until Saturday
    Saturday:
    plug in old hard drive
    run chkdsk from new drive
    restart computer and restore windows to old drive
    restart computer, boot from old drive and create recovery CDs.
    turn off computer
    eat lunch
    remove old drive from computer
    turn on computer - no power
    power connector to mother board is loose
    reseat power connector to mother board
    turn on computer
    CPU fan is loud
    turn off computer
    clean CPU fan
    turn on computer
    power connect tor mother board is loose again
    turn on computer
    copy some old runtime files from external drive
    I still need to copy around 25 GB worth of stuff for Daz Studio and Poser 9.
    eat dinner
    Post edited by starionwolf on
  • RezcaRezca Posts: 3,393
    leetlest dragon
    Nah, the dragon is big - the terrain is just even biggah!
    I'd have put a human next to her as well but... I was too lazy ^^
  • DanaTADanaTA Posts: 13,350
    Kyoto Kid said:
    ...homebuilt so none. (one of the pitfalls of trying to save a few Zlotys, besides, most "off the shelf" systems usually have a barely adequate PSU are usually in a cramped case with sub-par ventilation and come bundled with a load of crapware I'd never use).
    The issue is it's worked fine until this bluescreen crap started last week.
    Whether the card came in a pre-built system or you bought it and put it in yourself, there is still a warranty on the items! It seems to me that you haven't had this new system very long.
    Dana
    Yes, re-seating the video card, and other cards as well, is a good idea.
    Dana
  • SiscaSisca Posts: 875
    I bought my current computer just over a year ago and except for power outages it's never been turned off. I don't even let it go into hibernation since neither Windows or Mac hibernation can be trusted to not corrupt your drive.
    When I first got out of the Navy I worked for one of the major computer manufacturers and I've had power supply engineers say to never turn the system off as startup is the most stressful time for a power supply. I've had board engineers tell me not to power down since heating and cooling could actually cause issues with the solder joints.
    Of course I've had other engineers tell me exactly the opposite so no matter what you do you're probably right :)
  • ps1borgps1borg Posts: 12,776
    Morning. A bit of spring came back with the morning sun, blue sky and warm outside, bushfire alerts on the radio all morning :>)
    Oh noes, we need a detective fast
    215 x 227 - 84K
    I only turn mine off if there's a power outage or when I go on vacation. And I've had pretty good luck with them really. I don't update very often. When I do, I go all in, as much as I can afford to at the time. As things are now, the next time I can afford to do up a whole new system, there will probably be a Core i10 with 6 or 8 cores in it. What I'm waiting for is the crystal data storage. I don't know what they're waiting for. It may be permanent storage, but it would be virtually endless in capacity. I read about them years ago. Maybe only the rich have them already. Could be a big secret. :coolsmirk:
    A laser would write and then read data from the crystal. When it seems the crystal is at capacity, the laser would change its angle just a hair, and have a clean slate (plane) to write to. The change in angle would be measured in a fraction of a degree, from what I remember. When I read this, I remembered the sci-fi of the early 70s...Star Trek, Buck Rogers, using crystals for data storage. The sci-fi writers are the actual innovators and inventors...the scientists and engineers simply see an idea and try to make it work.
    Dana
    Walk cautiously!
    Dana
  • TJohnTJohn Posts: 11,343
    Kyoto Kid said:
    ...well the bleedin' site software is acting stupid again (what's new?). Found myself suddenly logged out on the store page and every time I sign back in I'm misdirected to the account page. When I switch back to the store tab after signing in, I find I'm logged out again. This has gone far beyond ridiculous.
    It's been nearly a year and a half. You would think by now with all the tickets and complaints they have received from the community on issues like this, that it would have been fixed by now.
    Clearing cache and cookies doesn't fix it either.
    They need to bring a group of professionals, sit down with them tell them everything they want this bleedin software to do, and let the experts take care of matters and get this site working right once and for all.
    That was happening to me yesterday. When I changed the display per page # to 60, it fixed itself. No idea why but it seemed to be caching to that page (logged out) when displaying 15 per page. Even a hard refresh wasn't helping.
    How long have you been holding him? Judging by how long his hair has grown, it must have been months now. :)
    Just start cutting on him starting with his hair. :lol:
    DanaTA said:
    What does RRRR stand for?
    Dana
    Well, if you say the R's one at a time, it kinda sounds like a seal barking. :)
    DanaTA said:
    ps1borg said:
    The Studio and Carrara libraries are integrated with the programs. Flash is banished from the Apple world. I use the Air library, 64 bit Poser and having no problems at all with it on Mac OS. Only downside is Carrara won't run on modern Mac OS and Studio only has rudimentary animation capacities so I use Poser to Lightwave, works real well for me but I'm banished from the DSON world by (mostly) UV issues. Can't recall a time where compatibility has been such a drama Sierra Nancy Alpha Foxtrot Uniform :>)
    Speaking of Air, I got a little popup message in my tray last night that I might not have the latest version. The thing is, I never had any version to the best of my knowledge. :-S
    Dana
    Then you definitely don't have the latest version. :)
    edited October 2013
    quick test render of Kid 4 girl on an asteroid.
    Memory usage:
    Daz Studio 3 / 3Delight: ~290 MB
    Video Card / openGL preview: ~ 90 MB
    I might run out of video memory before I run out of system memory. Eeek.
    Daz Studio spent almost four minutes rendering Renee hair and the shadows.
    640 x 480 - 157K
    Memory usage:
    She's gonna need a pressurized spacesuit there. :)
  • TSasha SmithTSasha Smith Posts: 27,317
    Having computer problems right now.
  • JaderailJaderail Posts: 0
    That all depends on Who you have build the system. This monster is, well a monster, but the company I used will BUILD any PC to your specks. And you get a Free 1 year coverage on all parts. And the Win 7 Pro I had installed is JUST Win 7, no clog ware included. The monster also has a 1400 watt supply that Covers all my fans and liquid cooling needs plus some. Sure it cost's more for a build but I'm happy as a clam with this thing.
    OK, just happened again. This time a CTL-F5 worked to fix it. Must be some kind of onsite caching problem.
    tjohn said:
    Dana
    This is true. :smirk:
    Dana
    Memory usage:
    Cue Sting song...Walking on, Walking on the Moon.
    Dana
    And they threw in the Snail-Speedy Delivery for free. :)
    After all that angst they put you though, I hope your new system is everything you wanted and more, Jade. :)
    I've been playing with the new AoA Advanced Ambient Lights. Tons of fun and lots of test renders but nothing to show yet. But they are awesome.
    I want to play with my new toys but this computer is having difficulty starting.
    Funny, I am trying to make a spacesuit for the kids and young teens. I'm still trying to make a plain dress for Laura 3. i'm also trying to make my own little space station in Hexagon. Now all I need to learn is how to rig doors and windows.
    o.k., bye
    edited October 2013
    Dana
    I actually had that concept in an old sci-fi RPG campaign I GM 'd. It used a three dimensional holographic crystal array. This was back in the 1980s.
    ...glad that course I took in abstract matrix algebra, actually had some use.
    Post edited by kyoto kid on
    ...I built it. On my budget couldn't afford a custom setup service.
