Hi. Does anyone know what happened to the Geometry editor in Studio
StratDragon
Hi. Does anyone know what happened to the Geometry editor in Studio? I looked info here and Google because here never worked and I imagine it still doesn't but it no longer shows in my menus. Or is there another way in DS to select a surface and make a shell of just that surface?
Post edited by StratDragon on
try self serve view
it has a Vray one, export
I'm using City Limits and have been for years. I stopped using DS around 4.5 and came back sometime after 4.10. It's not in Self Serve layout but thank you or are you asking me to export something for Vray?
menu > window > panes > tool settings > active tool: geometry editor
also alt+shift+g
you original post mentioned exporting stuff to render unless I am going bonkers
it should be in the Tools menu, as long as you are running the pro version (that is, have entered your serial number).
@Wendy
If I did it was unintentional. my solve was to export to blender and run it back but I don't recall writing that. I have a thumping head cold right now so I might have before I edited.
@Padone,
It's just gone.
@Richard,
I think it said 4.10 advanced. it's been a while; is there an advanced and a pro? I'm not in front of the computer now.
There was an Advanced, as I recall - are you using an old, paid-for, serial from the first release (before DS 4 Pro was free for all)? If so try registering, that should get you the free Pro serial number (which won't enable Decimator, but will enable all the other tools from the original Pro version).
