Advanced Ambient Light: Problem
NiffgorNiffgor Posts: 53
Probably I am overlooking something obvious - or I am just too dumb.
I do not find any controls for the Light. I can just change the colour and the intensity - nothing else in the parameters (or anywhere else).
Any suggestions or maybe even a solution?
  • Richard HaseltineRichard Haseltine Posts: 109,630
    Are you using the beta or the production build of DAZ Studio? Did you install manually or via DIM?
  • NiffgorNiffgor Posts: 53
    Win 7 Professional (64 bit)
    DAZ Version 4.6.0.18 Pro (64 bit)
    I tried the installation via DIM and manually - no difference
    There's a folder called "DAZ Studio 4.5" in the zip containing folders called "scripts" and "shaders." These two folders have to be copied into your library, too. I don't know why they're not in the Content folder.
    Greetings,
    Installing via DIM acted like a software install for me. In fact, I have my content directory ('My Library') mirrored using DropBox to another system, and the Ambient Light did exactly what the OP described on the system that stuff got mirrored to. I had to re-do the install on the mirror system in order to get Ambient Light to show all the capabilities.
    Essentially the 'software' part didn't get installed, is my guess.
    -- Morgan
    Those need to be merged with the matching folders in the application folder - that's why I was asking if it was the beta or the release version being used.
    Oh, gotcha. Well, that explains why what I did worked when I did it on my main machine (which has the application and the content library in the same folder).
    Problem solved with this solution:
    sioc said:
    I opened the zip (DIM) and installed it manually: the DAZ Studio_4.5 part in the program folder and the content in My Library, now I got them in Light Presets - Age of Armour - Ambient Light. And I re-imported the metadata and it appears in the smart content lights category.
