sss render
Thadeus72Thadeus72 Posts: 415
hi
when i do a render with the sss setting i 've got this problem
thanks for your help
i use the last version of daz studio and i 've got windows 7 64
  • frank0314frank0314 Posts: 14,765
    Try turning your pixel sample up to 16-20
  • Thadeus72Thadeus72 Posts: 415
    thanks it 's better but i ve always got the seams ...
    It is the surface settings. Make sure all surfaces with the same Group ID # have the same value for Shading Rate and for Shading Scale, and you will probably want to reduce Shading Rate to 4 (I go as low as 1 but I am playing with toons at the moment).
    great thanks it work !
