Spiderman Problem
RKane_1RKane_1 Posts: 3,039
edited March 2019 in The Commons
This is weird. I cannot figure out why there is a black coat around this figure.
Here is the figure not in an IRAY render
Here is the render in Iray
Here is the figure with the suit invisible and the torso visible in IRay render
In IRay render with the suit visible and the figure invisible...
Post edited by RKane_1 on
  • 3Diva3Diva Posts: 11,974
    edited March 2019
    Looks like something off with the surface setting for the torso map.
    Perhaps a screen capture of the surfaces setting for the torso might help narrow down what might be the issue.
    What you could do, is copy the Legs surface in the Surfaces Tab and paste it into the Torso slot of the surface tab and then manually change the Legs texture maps to the Torso texture maps and see if that gets rid of the issue.
    Post edited by 3Diva on
  • RKane_1RKane_1 Posts: 3,039
    I did try that trick right off, believe it or not as the black spot covers the torso area exactly. It did not work.
    Also, wouldn't also making the figure invisible and leaving the bodysuit visible solve that nproblem? For some reason as the pics above show, the figure is invisible in one but the boidysuit is turned on BUT, we get the same problem. Weird. I even made the opacity of the torse o% and it still shows.
    I wonder if it is just a glitch.
  • nonesuch00nonesuch00 Posts: 18,729
    The normals might be pointing backwards.
    Here is where I asked a while back & Richard Haselstine answered.
    https://www.daz3d.com/forums/discussion/313106/le-village-help-i-think-it-s-reversed-normals
  • I would say if all else fails put a ticket in !
  • HavosHavos Posts: 5,586
    Did you add a geoshell to the suit and/or the figure, if that is present and wrongly configured, it could cause the issue you are seeing.
