Is DazStudio Visible Yet?
franontheedge
Does the latest version of Daz Studio have larger text on it's menus etc?
If not, why not?
It's almost impossible to use now the text is so tiny.
Greetings,
Are you using the Darkside style? Main Street and Highway seem to have larger fonts.
I can't figure out the *.style file format (maybe it's a Qt thing?) unfortunately, so I don't know how you can configure it. It'd be nice if we could build our own styles...
Under Window, Style | Select Style, you can pick one of the other UI versions and it might be better for you.
-- Morgan
Thanks for the reminder on how to change the colours of the text anyway. At least now I have dark text on a lighter background, instead of pale grey text on an only slightly darker grey background. It was impossible and such a strain on the eyes.
I didn't pick a different UI, I just adjusted until I could see the text - is there a way to save the style?
I think there used to be, but this DazStudio Pro 4.5 looks so different that I'm having trouble remembering where everything is - since some things seem to look so different even if they turn out to be in similar places.
Thanks for the reply, very useful.
For bigger text I'd make sure you're using the Main Street style (Window->Style->Select Style) as it starts with bigger text and icons. Then you can change your colors to something that works for you.
To save your changes go to Window->Style->Save Style As and give it a name.
Ah... unfortunately it turns out I'm already using the style 'Main Street' - the text is really really tiny.
I've saved the colour adjustment I made to it.
Thanks for telling me where to do that, it's just so hard to see even with the adjustments...
I've already changed everything I can in the control panel/personalise to make text bigger and yet still get everything on my screen... sigh.
Fran
