Render size
in New Users
Here is a picture of my project.
As you can see it only renders what is in the square box. Is it possible to make that box bigger so that it renders the entire screen?
is that a good idea or what are the issues of doing that?
Thank you
Go to your Render settings tab and up to "General" and change Pixel size and Aspect ratio.
Aspect ratio shows you what will be in the Render and Pixel size how big the image is.
You can also use numbers of say 2000x3000 in the aspect ratio instead of the default 3.0-2.0
If you look on the render settings tab, general options, you will find pixel size and aspect ratio at the top. There is also an option to lock aspect ratio so you can alter the width (for example) of the image and it will automatically recalculate the height.
The only issues with altering the pixel size so that it cover the entire screen are that your render will take longer.
Cheers,
Alex.
