Lighting addons for 3DDelight?
in The Commons
Hi , I was looking for lighting packages and I came across 'ghost lights' which is for iray, are there any similar lighting packages specifically for 3Ddelight? Thanks
Not exactly the same but there is this for 3DL: https://www.daz3d.com/architectural-lighting-rig
It's very easy to create a ghostlight for 3DL. Create a primitive plane with 1 division, apply the Omnifreaker area light shader, with the plane selected go to the surface pane. Turn on Fantom, that will make the plane invisible to the camera. Activate shadows (if you want it to cast shadows) and fall off (if you want it to behave realistically), up the samples to atleast 64, adjust color and strength. Position your plane and possibly make instances of it if you need more lights. Render:)
