The Path to Cloud Temple
dassoubarnadassoubarna Posts: 7
I try to render DAZ Studio 3D Light render of the following product with the Camera and Lights that comes with the product. But the rendered output is not as the promo images of the product. Can anyone suggest me the technique by following which I can get the results as the promo?
https://www.daz3d.com/the-path-to-cloud-temple
  • LeanaLeana Posts: 12,819
    Can you be more specific? What is different?
  • MattymanxMattymanx Posts: 6,997
    Dassoubarna,
    Are you rendering in 3Delight or Iray?  The product predates Iray so its only optimized for 3Delight.  If you render in 3Deight wiht the included fog camera and uberlight then you should be able to get the same results as the promos.
    Mattymanx said:
    Dassoubarna,
    ...unless something is seriously off with the render settings;)
  • I load the scene by double clicking it. In the same way I load the light and camera preset that comes with the product, then change the render settings to 3D Light instead of IRay and press the render button.
    Rendered without Uber Light applied:
    Rendered-Without-Uber
    Rendered with Uber Light:
    Rendered-With-Uber
    Render settings:
    1
    2
  • Richard HaseltineRichard Haseltine Posts: 108,533
    Moved to Rechnical Help as it is a question, not a Product Suggestion.
    Please post full resolution screen shots, by downsampling you have made them unreadable (at least for me). What do you mean by Uber Light? Whata re you wanting to achieve?
