Obj won't read texture content after imported on Daz
I'm trying to import a textured obj. But when I do it, the obj won't get the textures.
Sounds like an easy question, but I don't know how to solve it.
Post edited by raphaelmartines on
  • LeanaLeana Posts: 12,900
    I don’t see a MTL file with your OBJ, that’s what tells DS to load the textures.
    Thank you, I've forgot this one. Thanks!
    Note that there are lots of ways DAZ|Studio can fail to read a .mtl file — the obj/mtl file format is ancient in computer terms, and many of the 3D programs that can import/export it use almost (but not quite) identical ways to set up the .mtl file. If you have any problems, post here again and someone ought to be able to help. Usually the solution is a simple text search/replace to fix dud file paths.
