Having issues with Genesis 2....Help please?
Ive been exited to use her in some upcoming work....But i cant get ANY materials on her....i can only get textures on her manually, which is frustrating since i have to then manually get all the bump maps on her too lol Is this a problem with G2? Ive uninstalled her and re-installed her twice already and i get the same...i also did the same with Daz Studio 4.6 as well, uninstalled and reinstalled....didnt help. Id like to just click the materials on her lol
And while im at it....is there any way to REMOVE the SSS skin shader? its killing my render times. Thanks in advance!!!
It sounds like you might be trying to apply materials that are not in .duf format. Because her material zones are named differently than Genesis 1, it seems that only materials with the .duf extension will apply using presets. If this is the case, try applying your material to Genesis first, then save the material setup as a .duf file. It should then work on Victoria 6 and the Genesis 2 Females
Thanks ALOT! Im going to try that right now!....Though, I read the same earlier and i did open Genesis 1 and transfered the textures perfectly, ONLY that i had to do it manually....The files i tried "clicking on" to Gen 2 said "DSON User File" as the file format....thats duf right? If so, then those arent working either. But since those are the default files, im going to try and make the duf's myself to see if that helps.
