dampened spring oscillation experiment script for weekendish nerd waste of time
over here http://gafferongames.com/game-physics/integration-basics/
someone shows how to implement physics simulations using an RK4 integrator
and here's my implementation of his c++ source as a Daz Script
1 - create a cylinder, 30cm tall 1 cm diameter
2 - select the cylinder
3 - run the script
the Z rotation angle of the selected cylinder will be driven by the simulated output ( x )
the line that reads "if( (cpt++) > 200 ) break;" is a safety device limiting the simulation to 200 frames
cpt also serves as the keyframe time
you may want to replace
zRot.setValue( cpt * tick, state[0] );
by
zRot.setValue( t * 4800, state[0] );
g_k is the Hooke's law spring constant, g_b is the dampening factor
you can download the script here
https://sites.google.com/site/mcasualsdazscripts3/physicsrk4_001
there's also an HTML5 ( camvas + javascript ) "app" to visialize
the simulation as a curve and as an animation, right in your (modern) browser!
//implementation of <a href="http://gafferongames.com/game-physics/integration-basics/">http://gafferongames.com/game-physics/integration-basics/</a>var g_k = 10; // spring constantvar g_b = .4; // dampingvar onesixth = 1 / 6;function acceleration( state, t ){ return( - g_k * state[0] - g_b * state[1] );}function evaluateA( initial, t ){ outputdx = initial[1]; outputdv = acceleration( initial, t ); return( [ outputdx, outputdv ] );}function evaluateB( initial, t, dt, d ){ state = new Array( 2 ); state[0] = initial[0] + d[0] * dt; state[1] = initial[1] + d[1] * dt; output = new Array( 2 ); output[0] = state[1]; output[1] = acceleration( state, t + dt ); return( output );}function integrate( state, t, dt ){ a = evaluateA( state, t ); b = evaluateB( state, t, dt * 0.5, a ); c = evaluateB( state, t, dt * 0.5, b ); d = evaluateB( state, t, dt, c ); dxdt = onesixth * ( a[0] + 2.0 * ( b[0] + c[0] ) + d[0] ); dvdt = onesixth * ( a[1] + 2.0 * ( b[1] + c[1] ) + d[1] ); state[0] = state[0] + dxdt * dt; state[1] = state[1] + dvdt * dt;}function main() { zRot = Scene.getPrimarySelection().getZRotControl(); tick = Scene.getTimeStep(); var state = [ 100, 0 ]; var t = 0; var dt = 0.1; cpt = 0; while( Math.abs( state[0] ) > 0.001 || Math.abs( state[1] ) > 0.001 ) { debug( state[0] + " " + state[1] ); zRot.setValue( cpt * tick, state[0] ); integrate( state, t, dt ); t += dt; if( (cpt++) > 200 ) break; }}main();
there's also an HTML5 ( camvas + javascript ) "app" to visualize
or you can copy & paste it here .... not ,,, since the forum removes javascript tags
i was reading the comments on 's page
and apparently springs-based rigging may be discarded in favor of something called "soft constraints"
https://code.google.com/p/box2d/downloads/detail?name=GDC2011_Catto_Erin_Soft_Constraints.pdf
Reminds me of a car window wiper. Starts off good, and slows down as the window dries.
