Mirroring and fitting a brace
SylvanSylvan Posts: 2,719
edited September 2013 in Daz Studio Discussion
I have a brace for genesis' arm and I want to mirror it so he can wear it on the other one as well.
Thing is, that it's an item that needs autofit because it's a gen3 item.
So how can I mirror this item and then auto fit it to the other arm?
Post edited by Sylvan on
  • Richard HaseltineRichard Haseltine Posts: 109,296
    You could try this:
    Load the autofitted brace, without fitting it with no posing or morphs applied. x-scale it to -100%. Make sure it lines up with the zeroed Genesis' leg. Assuming it does, hide or delete everything else in the scene and export as OBJ (using any preset). Load Genesis and import the OBJ, using the same preset as you used for export. Edit>Figure>Transfer utility, set Geensis as the Source and the brace as the Traget and click OK. Test to see if the new figure works - if it does, Figure>Save as>Support Asset>Figure/Prop Asset.
  • SylvanSylvan Posts: 2,719
    Awesome, thanks.
    I'll try it out tomorrow as it is almost midnight here in europe ^^
