Problem with content manager
Pendraia
Hi, I did try and check on Mantis if this a reported issue but I'm getting page not found for Mantis.
Can anyone tell me if they are having issues with Content Manager duplicating folders when using the duplicate category/sub categories option? I'm finding that it's not merging the folders but actually creating duplicate folders. For example I now have 3 or more figure folders. Also when I try to create a new folder nothing is showing up and if I try again I get a message saying that it can't create the container.
This has been happening since I inadvertently installed the beta and then uninstalled it.
Any suggestions on how to fix this?
thanks
Pen
Bugs are now reported to Zendesk, not Mantis. Tech Support.
Eventually the Zendesk will have a full bug reporter, similar to Mantis.
I am not sure, but I don't think so at the moment.
Hello Pen
Could you please explain your problem a little more fully, and tell us what version of DS4.6 you are now using?
I have never used the Duplicate option in Categories (I don't know what it is for?), but since it only adds to the database, I don't think it should be creating folders at all. Do you mean physical folders on your HDD, or just extra folders in Categories? I would have thought that creating extra entries (folders) in Categories is what the option is for, or why would one use it?
Edited to add: It's folders under categories that I'm talking about. I always organise content internally in DS.
It sounds like your database may be corrupt.
1) If you haven't exported user data recently, do that first, so you can restore the categories that are still working.
2) Close DS and uninstall CMS.
3) Reinstall CMS by running the installer in C:\Program Files (x86)\DAZ 3D\DAZ3DIM1\cms (if you have DIM installed) or by reinstalling DS. That will give you the latest CMS, which will reduce the chances of the problem recurring.
4) Search for the file ContentDB.ind -- if you let CMS install to the default locations it will probably be in Program Files (x86) or ProgramData. I would search your entire hard drive with "Hidden and System Files" visible, in case you have more than one set of databases, which could also cause problems. That file is the index for the database.
5) Stop CMS and delete ContentDB.ind, then start CMS and launch DS. Let DS rebuild the index -- it might take a minute or two.
6) Scan for new content and categorize it.
7) Close and restart DS, and see if the categorized items are staying. If they are, you should be good to go.
8) If newly-categorized items are still disappearing, close DS, stop CMS, and delete all the files in the databases folder. Restart CMS, launch DS, and re-import metadata to get your user data back. It can take a long time, so don't panic if it seems to be taking a long time and the progress bar isn't moving.
thanks Mike, I'll give that a go once I'm more awake...just got up. To reinstall cms via the DIM I would need to uninstall first via the start menu and then uninstall DS via DIM and then reinstall it?
Uninstall CMS from the Start Menu, then reinstall it from C:\Program Files (x86)\DAZ 3D\DAZ3DIM1\cms -- you don't need to uninstall/reinstall DS.
One last question where do I find the database folder...
Probably either "Program Files (x86)\DAZ 3D\DAZ Content Management Service\Databases" or "ProgramData\DAZ 3D\DAZ Content Management Service\Databases"
Just wanted to let you know everything now seems to be working. I did have to reinstall the Genesis essential starters also but can now created new categories and it doesn't appear to be duplicating folders anymore. Thanks again for all your help!
