Can't download anything I've purchased
Ladymist95
I've been trying to download the stuff I bought a few days ago and it starts then fails shortly afterwards. I've tried both manual download and using Install Manager but the same thing happens with both. It starts with a download speed of thirty-something and within seconds goes into teens and then fails. Usually, my download speeds are in the one hundred seventy something range or more. Tried clearing the cache to see if that was the problem but no cigar. I've tried several different products but the same happens with all of them. I've purchased and downloaded a lot of products from DAZ and never had this happen before. Bought the stuff before work and downloaded several of the items with no problem but when I got home and tried to download the rest this problem started to happen. Arrg I just want to play! HELP!!!!!
PS wish they had a crying smiley here
What packs are failing? Most of the time its your ISP going up and down. It's fine when you start but part way through you lose your connection for a second and it comes back up. Have you been getting booted from the internet lately maybe your ISP is having issues.
If doing "manual downloads" in FF, one can right-click on the download link and use the "dTa" Download Helper plugin to get the file(s) ... it has the marvelous feature of being able to restart the download on its own and shows very clearly if the download is good or not.
