Backwards compatibility G8 to G3?
This has probably been asked or expalined before but I guess I'm not searching right.
I am working on a story and the male character is a G3M. He desperatly needs wound care with https://www.daz3d.com/skin-doctor--blood-and-bandages-for-genesis-8-males due to his head wound. My fear is that it won't work due to the conflicting generations. I tried to fit G8 clothing to G3 back when G8 first came out. Is there a produc to retrofit?
Thanks for the help.
For the woulds themselves they are using the Layered Image editor (LIE) , that means you can alway apply them yourself to any other figure. For the bandages there is this product : https://www.daz3d.com/get-well-soon-props, but it does not have a head bandage. you could try to load it from the skin doctor without the autofit and then manually place it to the head . remember to change the parenting to the head then as well before posting your figure.
As for backwards fitting, I'm using this: https://www.daz3d.com/sy-genesis-8-clones-for-genesis-3
there might be others around. it works fin for most cases, in some its still working better without the autofit, especially when you don't need the change on the arms base position
"you could try to load it from the skin doctor without the autofit and then manually place it to the head . remember to change the parenting to the head then as well before posting your figure."
I think I know what you mean. I had some trouble getting the shaping morphs to work on G8 characters when I was applying G3 hair. I think this was the same method prescribed to make them work and it did. Thanks for the tip! It's the same principal, I guess it just didn't occur to me because I was thinking it was a "hair thing." Thanks Linwelly!
