Betty Hair problem
dholmdholm Posts: 115
I have some blue triangles two in front and one in the middle of her back. I used V4 because the icon said Betty Victoria4. I have not tried it on the Gens. How do I get rid of them?
  • MattymanxMattymanx Posts: 7,000
    They are known as handles. They are an older method of showing controls for hair morphs and was used on dresses in the past as well.
    There are two ways to hide them depending on whether or not the hair is a figure or a prop.
    If its a figure then you should be able to find the handles in the figure tree in the Scene Tab.
    Also, regardless of figure hair or prop hair the handles should have their own surface so they can be made transparent.
  • dholmdholm Posts: 115
    Thank you That was a big help.
    I just had time to try and hide just the triangles but the whole hair disappeared. If someone can will you post or drop me a pm on how to hide just the triangles step by step. I'm still trying to lean the terms, software ect...
  • JaderailJaderail Posts: 0
    Surfaces, Helpers or Handles or whatever the name, and set Opacity to 100% or 0% which ever turns them off. I get it backward half the time.
    Thank You I was looking in the wrong area of the software.
    1208 x 679 - 65K
