Where is my 'shaping preset'?
in New Users
As showing in the picture, there is nothing in the "shaping preset" pane, but I have just saved .duf shaping setting file for testing, in both the default C:\ storage area, and the F:\ folder which I installed the software, it is not appearing in the pane, what's the problem? Is my software damaged and need to be re-installed?
If I start a new file, don't load a figure, just directly open that saved shaping preset .duf file, it report an error and the log file is like this:
10:44.178 Invalid node selection for "preset_shape" type.
10:44.178 Error reading file, see log for more details.
Did you forget to attach the image?
You need to have the figure selected for the preset to work, it is to modify an existing item not load a new one. The Presets tab of the Shaping pane also relies on having the figure selected if you have Filter by Context checked.
