[Released] Attack-V
New to the store is the Attack-V VTOL. Folding wing, props and retractable landing gear and working hatches are all posed with a single click.Chose between two colors, Black and Gray.
  • Curious why it has two fixed-firing guns on the underside. A retractable turret was apparently designed to be mounted in the rear bay, but was found to not be workable and never entered service. The only forward-firing weapons it has are meant to be some (laser-guided) rocket pods mounted further up:
    https://foxtrotalpha.jalopnik.com/the-v-22-osprey-finally-gets-the-missiles-and-rockets-i-1668338371
  • Not many photos of the V-22 with weapons  I did try the TOW rocket pods from "Rotorheads military upgrade "  Maybe ill add them and the tail ramp gunnder. not many places to add guns
  • Yeah, that's what I'm saying, though. Can't find any references to guns being fitted. Looks like it has rocket pods and the internal ramp gunner, but no turrets or gun pods on it.
    The rest looks good. :)
  • Thanks!!! :)
  • Could someone tell (or show!) if there are seats inside in the cargo hold?  I need a VTOL, but I need seats :-)
  • It isn't clear if the props blur..
  • Yes there are seats that can be set to the up position or down.
  • Blur is only posible using a texture map on the (prop disk) When using the disk you can turn the blades texture off using the (Blades on and off) option under the Pose section. A texture is supplied in the Runtime texture folder. its called "disk3"
