Carrara 8.5 and "Genesis 2 Male"
FetitoFetito Posts: 481
Two questions:
1) According to the patch notes, Carrara is compatible with "Genesis 2 Female", but what about "Genesis 2 Male"?
2) Can I apply Genesis 1 clothing on Genesis 2 figures?
Thank you!
  • PhilWPhilW Posts: 5,162
    Genesis 2 Male is not yet available, but I am sure that it will be compatible as it will use the same underlying technology as G2F, just a different base shape and morph set.
    I believe there is an issue with Auto-fitting from Genesis to G2F. It works with earlier generations, but not (yet) from Genesis to G2F.
  • FetitoFetito Posts: 481
    @PhilW: Thanks!
    Just to add that Genesis clothes can be fitted to G2F in DAZ Studio, so you could look at fitting there and then exporting to Carrara.
