Adding to Cart…
I was doing the same comparation just before reading your post. And I think your are definitely right! The GPU works and win10 just does NOT know!
Here is my statistics:
Hardwares: i78750 (6 cores 12threads), GTX1050Ti 4G
Picture: 3840*2160, 400 iterations.
total time and iterations CPU load GPU load "GPU memeory"
GPU + CPU: 8mins, 400iterations ~100% 0% (did not noticed)
GPU only: 10mins, 400iterations ~33% 0% 2.5
CPU only: cancel after 12mins, 85%, 187iterations 100% 0% 2.3
So yes, there is nothing wrong with the DAZ studio and the NVidia driver. Win10's bad.
And, the CPU helps; when I chose CPU only, that's a real "100%" and I cannot even type.
I think, the render call gpu directly, but not pass the os api.
You are not reading that graph from Win 10 correctly. By default in that column it shows GPU load for 3D computations. However, iRay uses CUDA API to interact with the videocard, so, you'll not see it there. Open performance tab in the Task Manager, click on GPU in thew left panel - you'll see several different graphs. Click on the name of one of them, like, for excample "Video Decode" and switch it to "Cuda". Here you will see how much iRay uses it.
Thanks! following this I can finally see that my card is in use (between 90-100% usage of Cuda cores, which seems good to me)
