Move Frame "x" to frame "0"
NEK4Killer
Hi, is there a way to delete as example frames 0-3 as and frame 4 then becomes frame 0?
It's about that I created several scenes, unfortunately I didn't pay attention and the scene is on frame 4.
I already tried to save and restore all objects with "Edit-Object-Memorice-Selectet-Items". It almost works, but certain facial expressions and poses are not adopted.
Deleting the first frames would be better.
Thanks.
When saving a pose preset you can, in the options dialogue, choose tos ave only the current frame or a range of frames. If you save the current frame at frame 0, then delete its keys from the timeline and apply the pose in frame 0, that should get what you want. You may also need to save a Shaping preset, or even a properties preset to cover both, if you are having trouble capturing all properties.
Hi, thanks for the quick answer. So there is no way to delete it directly or move a complete frame including all poses, shapes, object positions etc. at once? :/
I don't think I can save simulations, but only the simulation settings. If I understand that correctly.
Not by default, I'm not sure if KeyMate or GraphMate add the ability.
ah ok I try to check it. Thanks.
