Zero out morphs?
How do you go about zeroing out all morphs on a character?
I now about the pose reset but I have a problem with some poses where when applied suddenly wierd things happen to the face like lips a foot long?
There must be a way to zero out a morph without having to manually search all possible shaping morphs and try them one at a time to get back to a zero position.
Perhaps a script I can install to use anytime I run into this issue?
Thanks
  • MattymanxMattymanx Posts: 7,000
    With the figure selected, on the parameter tab on the left, look for "Currently Used" and all active morphs will show up.  You can then Alt+Left Click any of them to zero them.
  • Edit>Figure>Zero>Zero Figure Shape.
  • One quick caveat to the previous replies. Sometimes presets change the default parameters, min/max or default/value, of a morph dial and require manual zeroing. These types of changes don't appear on "Currently used". You'll have to click on the gear icon and change the values in the popup to zero manually.
  • Thanks for this. Been looking for the ability to do this.
  • nicsttnicstt Posts: 11,715
    The Alt-Left Click is great; if it doesn't work, it is becuase it's being controlled by another slider.
