texturing a cube with seamless tile
davesodaveso Posts: 7,850
edited February 2019 in The Commons
I have been messing around with trying to skin a cube with a seamless tile ... see image.
Note how the top does not match the sides. The sides seem to be seamless ..the top not. Is it possible to have the seamless carry over on all sides?
Post edited by daveso on
  • well it is but not using just any texture
    rather a texture that is mapped to it
    I have spherically mapped cubes to take 360 photos but even that not good you get distortion
    however you can get a 360 image remapped to fit a box mapped cube beautifully
    that is one way to do it, use a program for creating skyboxes like panorama tools
    the other way is 3D painting
  • davesodaveso Posts: 7,850
    so like breaking down the cube flat ... and then applying the texture? as in UV mapping. And Carrara can do this?
    not well no
    a dedicated UV mapping program could but I would honestly not go the spherical route myself
    rather convert the texture to a cubemap
    I am trying to find something I can actually link thats noncommercial
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,264
    https://docs.unrealengine.com/en-us/Engine/Content/Types/Textures/Cubemaps/CreatingCubemaps
    dunno if that helps
    I have an old qtvr program that does it I think no longer has a free version
    pano2VR
  • Oso3DOso3D Posts: 15,090
    Well, there's always procedural stuff like my shaders. ;)
    if its a truely seamless texture another way is to simply flatmap each side of your cube to overlap the others
    I had a quick go in my favourite UV mapper
    https://www.daz3d.com/forums/uploads/FileUpload/72/621661f423584485f86c3dfe3bc477.zip
    free to redistribute modify sell on secondlife use in porn (the mind boggles) whatever
    1919 x 1056 - 264K
    zip
    zip
    a cube with matching sides for textures.zip
    633B
    1000 x 1000 - 1M
    I made one also using deformation on a sphere
    so it;s really a sphere LOL
    https://www.daz3d.com/forums/uploads/FileUpload/83/2fbb0c774f6d2e407145a817d6ab3f.zip
    mmm the UV mapping seems to have changed on export
    this is rather odd
    zip
    zip
    panoramacube.zip
    33K
    1920 x 1080 - 224K
  • You can also adjust the tiling - if you set Horizontal Tles to 3 and Vertical Tiles to 2 each face of the cube will have the complete map applied, which will then join seamlessly if it's set correctly (all edges match - some will match horizontal to horizontal adn vertical to vertical but not horizontal to vertical).
    wow..thanks..yes... now, it's a square..why 3:2 ? i need to ponder this a bit smiley
    1007 x 901 - 897K
    indecision yes, but then I wouldn;t learn what I have today ... I was messing with PSP and came up with what I've done so far... its not for anything but the little ping ping that goes on in my head laugh
    what cool designs, whatever can i churn out?
    I used to do renders in Bryce by placing the camera inside a sphere or cube .. and if you applied certain shaders/materials, some wild stuff would come out of it ... maybe I'm ovrerly bored or something
    You got my attention now:)
    3 by 2 because that's the way the cube is mapped, two rows of three faces on the UV grid.
    ah ... simple enough :)
    Thanks everyone for the help./
  • I really was over thinking it and I knew the DAZ studio primitive cube had a 3x2 UV layout too
    thought this was a more complex issue with cubes in general and untiled textures
