About Export
It may be a silly question, but I would like to ask how can I export my daz files to fbx?
I googled and found that it should be files=>export, but I cannot find any "Export" Button Under Files
Which version of DS are you using?
DAZ Studio 4.6
Unlike yours, there is no any button after "save last render"
That's a very truncated menu you have. Have you modified your Layout at all?
... if not, try selecting Window -> Workspace -> Select Layout... and use "City Limits" - and see if that rebuilds your menus for you.
(you should at least have File / Edit / Create / Tools / Render / Connect / Window / Help as menu bar options... I recall reading in the forums here about a bug which left the menu structure truncated - it could be reset by switching layouts and/or styles back and forth...).
It works!
Thanks a lot :-)
I thought it was the default "training wheels" layout setting that left out many important functions. This question is asked at fairly regular intervals, it does confuse people, and some never realise (until they ask here) that they're missing anything. Changing the layout frequently solves many of these problems, but be aware that now you can see and use all of DAZ|Studio's functions, things can get more complicated.
