Leandro Hair Problem...
Upirium
Anyone have these problems?
Because I do. It seems to be worse on this figure inparticular. I use it on two. Both are m4. Their faces are different but I'm pretty sure their headsizes are the same.
So what is going on here?
Is there a fix to this? I have it fit to m4, too, so that's not the problem.
edit: added the other figure for comparison, I don't know what's going on
However the other figure does have problems when I pose his head certain ways.
Post edited by Upirium on
I have the same problem.
Here are the steps that fixed it for me:
- Disable the smoothing modifier (if you have one)
- Adjust the morphs so that the hair prop fits you figure (are at least until it is close enough so that you don't see a lot of poke through)
- Enable the smoothing modifier (add it if you don't already have it set) and set the smoothing to 2 and the collision iterations to at least 15
- In some cases, I also had to enable the Interactive Update option for it to work (not specific to this hair prop though, I have to do that for most clothes too, might be my computer)
Hope it helps :)
Leandro is prop hair. You say you have it "fit" to M4, by that do you mean parented or conformed? Prop hair is parented. By the looks of your screenshot I'm assuming you're using Poser, which the above won't do any good. Just parent the hair to M4 and use the scaling/translation to 'fit' the hair to the size of the head. You can save a pose to your library so you don't have to do it every time for that hair on that character.
As Vaskania mentioned, Leandro Hair is Prop hair which is parented to the figure. Normally that's done automatically as long as M4, in this case, is selected before you load Leandro Hair. You can also manually parent the hair to M4.
In Poser:
1. Select Leandro Hair, right click and select
2. Change "LeandroHair" Parent to>Michael 4>Body Parts>Head
There is a UP_Michael4.pz2 hair fit pose included with the hair. After the hair is parented to M4, apply the pose to Leandro Hair. The pose will position the hair to fit perfectly on M4's head.
