Stereo 3D and DOF settings
nierostanierosta Posts: 16
edited February 2019 in Daz Studio Discussion
Not sure if this turns out to be a newbie question or a feature sugggestion:
I'm currently trying to wrap my head around the "Lens Stereo Offset" in the Camera's lens settings.
This is a very useful and welcome feature, as is allows to render output directly without any post-editing - but it comes with a downside: For this parameter to work i understand that it is crucial to set the "Focal Distance" correctly to achieve correct convergence. I haven't found an option to bind the focal plane to an node, so i have to set the focal plane manually after each camera or subject change.
So what i'm trying to mimic is the same as the autofocus on a physical camera.
Did i miss this option somewhere? If not, is there a workaround or would it even be a feature to consider for an upcoming version of DAZ Studio?
Post edited by nierosta on
    Unfortunately there is no autofocus,
    there's a free script that you can use to parent a null to an object and then by running the script it will focus the selected camera to the null object.
    Here's the link
    https://www.daz3d.com/forums/viewthread/43636/
  • The Aim and frame commands will set the focal distance to the centre point of the selected item
  • Thank you both! I think i get the basic idea. Let's see if i can script that for an animation.
    One question though where i'd appreciate your knowledge: Is there a built-in function in DAZ Script where you can recycle the node selection dialog (see below)?
    535 x 768 - 28K
  • You mean launch it and then rad the selection? No, I'm fairly sure not - only the file/folder dialogues and the alert dialogues are built in to script
  • That would have been the idea behind it. Thanks for the quick answer!
