dForce Templar Outfit Textures
The outfit textures for the dforce templar,
https://www.daz3d.com/dforce-templar-outfit-textures,
are just not working whatever I do, I have tried reinstalling them several times. I do have the base outfit before anyone asks. When ever I try to bring up the library of the material files it looks like this, https://imgur.com/yefa96w with all the files corrupted. If I try to apply the textures to the outfit, I get this, https://imgur.com/D3ghCDi .
Anyone know how to fix this problem?
Post edited by timnikoley on
Looks as if the files are not decrypting correctly, assuming you are isntalling within Daz Studio - I've had that a time or two. Did you try restarting DS between uninstalling and reinstalling? If that doesn't help you may want to install with Install Manager, assuming that works, and open a support ticket to see if the issue can be resolved.
I've uninstalling within DAZ, with the download manager nothing seems to work.
The DIM install will be ignored if there's a Connect install of the product. If there isn't a Connect install and the DIM isntall still doesn't work then that suggests that your DIM install path isn't set as a content directory in DS.
