All my G3 figures keep getting deformed
All my G3 figures keep getting deformed - Especially the hands and the eyes. Never happens to G2 or G8??
See image!
  • BeeMKayBeeMKay Posts: 7,019
    If you pose, or on default load?
    This looks as if a morph is activated that shouldn't. Please check out in the Parameter or shape tab "Currently used" if some morph is activated that shouldn't be.
    Thanks a million-    this is what did it-Finally i get a real solution to my problem
    I'm glad you found the reason, though that's just half of the solution...
    If you know what morph caused the issue, and it's not supposed to be "on", then the best option is to uninstall the morph(package), and report the defect to Servicedesk (if it is a DAZ item) or the PA directly, from wherever you got the set. The reason is that the set was saved wrongly, and needs to be re-saved properly, and redistributed. smiley
  • My 3D SpinMy 3D Spin Posts: 609
    Now i have the problem again with deformed hands and eyes on G3F figures. And this time i made sure
    no other morphs was activated. The first image shows what  happens when i make the hand Grasp and
    the second image shows whaat happens when i also try to add height to the figure.
    900 x 1200 - 739K
    900 x 1200 - 702K
