After Burner!
richard.chaos_91798ec102
I think I got it...
I think I got it...
Looks really good.
Is that Primivol?
NO its the Rich Plug in! Its 2 cylinders tappered some. The color map is a Movie of 4 slightly different FALME images out of PS. with a black layer behind them I comped out of motion which is like the fools After Effects. SO I got a 4 frame movie at 30 fps. Copied and pasted it till I had 4 seconds. I uses the same movie for the color and the ALPHA to give it some see through and Feathered out the end.
Then I made a BUMP map out of PS by making a 50% Grey LONG rectangle in PS then gave it NOISE then a 90 degree motion blur Set the levels high on each end. then had that RUN by in about 6 frames from, left to right in Motion then made a 4 sec movie out of that.
Then put it all together on these 2 cylinders with a about a 12% Blur in carrara and a 8 percent aura and wal la! I am thinking of adding a GLOW to it
