These are some V3 Clothing I converted to V4 with crossdresser than used this to convert to G8F, if needed this post can be removed, not sure if it’s ok or not :/
A big thank you RSSY, for these products. Have had some old Alfaseed and Aeon Soul outfits forever and am finally getting them up todate. This example is Ony Tribal (Aeon Soul) for G2F, But have been bust batch converting som V4 stuff too from my now "irreplaceable" RDNA catalogue - have them backed up on a few drives too, just saying :) Haven't converted these to Iray yet, but have had your converter for a while and already know it will bring them to life as well.
The default autofit converter was okay, But your products just keep adjustments and add a few more. Amazingly impressed guys. Again, Thank you.
Thank you both so very much, a quick 1st try with Medusa for V4 and works a treat, the sleeves are perfect, skirt could have done with a little smoothing but this was just a quick tryout....well this will keep me busy for awhile ;)
Oh that looks good! I had never been interested in the medusa head but now I need to buy the outfit!
I don't know how long V4 and M4 were around for but I've got more clothes and hair for them than all my Genesis 1-8 content put together. It's a no-brainer for me to buy something that allows me to convert that older content without compromising the usability, and then dump the older version. I'm beginning to feel the same about Genesis 1 though I've got less content for that.
I'm afraid I'm not surprised the G3M to G8M hair converter did not sell so well, I think there isn't such a gap there to fill. It must be difficult given the time and effort you must be putting into this to judge how much old content is out there and how many owners of that content will buy these products. Personally I'll buy any generation 4 or Genesis 1 conversion product you put in the store!
BTW I've been a bit reluctant to get into G8 as I feel I'm having to buy things I already have and that my content is getting spread across so many generations. Consolidating content on G8 makes G8 much more attractive to me so now I'm looking to buy more G8 stuff! I suppose that probably means G9 is imminent...
Thanks for marketing such a great product.
You are welcome! For me, it's the reverse. I came in with G3 and G8 and have been reluctant to buy older clothing. Now that we have these converters, I have been taking advantage of sales and buying some older clothing!
V4 was released in December 2006, M4 in October 2008.
Wow, they are ancient in computer years!
And yet, for a huge percentage of this community, they are still the default figures and new product continues to be churned out for them. I can't remember the last time I actually used V4, let alone M4, but I continue to buy both new outfits and older products for them, especially when DAZ and the other sotres keep running crazy sales where they are only a few dollars each.
Huh. I have used G2m once or maybe twice. I have not been tempted to go even further back. However, there are outfits that tempt me if I can use them on G3 or G8!
Strange error I'm getting. I can't get it to process this item. I created the metadata myself, and it detects everything properly, but all the items get the same error when I try to convert them.
Check the conformer field. It looks like it has concatenated the conformer with the scifi pilot suit and that the sci fi suit is not in the clothing column.
I imagine the difference is that I started with this hobby back when Victoria 3 was the new girl on the block. Having thousands of older items and watching them become slowly obsolete as new products came in, especially given how often the older products were either better designed or concepts that were never duplicated, is a pretty good impetus to keep finding better ways to update the old stuff.. Especially since a lot of it actually looks amazingly good once it's upgraded to Iray or the morphs are transferred to the newer figures.
Just started converting. I am really impressed. I am even able to convert my XurgeXD clothing items which are some of my favorites. Even more excited than I was lol.
I understand completely. You have been using and loving these items for years. I have a soft spot for my first purchase from Daz for the same reason
I need the log to tell you why. But you can select them all and use Force Convert Item(s)
Thanks, the force convert worked, but the initial results are not that great. Very loose fitting and a bit warped on the mesh. Will keep trying to get better results t5hough.
I am going to blow my own trumpet and admit that I sent Powerage the sketches from which he based the style of that dress. There are quite a few alternative textures for it on my site, They do have DS mats as done by my son as well as the poser ones. but obviously no Iray ones.
I'm also having a problem with detection, here for example some clothing from 3D-Age. It detects some if it, but most are not detected.
The log file says it is skipping them? They are all in Character > 3D-Age in my runtime folder
The warping can depend a lot on the conformer used. Try other ones. For the looseness, that is intentional to make sure the conformers grabbed everything correctly. Use the Tighten All morph (or any of the other morphs added to the item) to pull it back in.
Well you should blow your own horn! It is a sumptuous dress.
That's certainly what it's doing. The filename is blank and the conformer is filled in with the filename. If I set the conformer, the proper conformer gets filled in and the filename disappears, and the the script converts zero items.
I'm not sure what's wrong, but I can't get it to work on anything. If I load from the content library, I always get the above error. If I load from files with check content type disabled, none of the items convert.
09:04:21 GMT-0500 (Eastern Standard Time): Adding Files...09:04:21 GMT-0500 (Eastern Standard Time): Adding "Follower/Wardrobe/Unknown" file: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STAHat.cr209:04:21 GMT-0500 (Eastern Standard Time): Adding "Follower/Wardrobe/Unknown" file: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPABoots.cr209:04:23 GMT-0500 (Eastern Standard Time): Adding "Follower/Wardrobe/Unknown" file: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPACorset.cr209:04:24 GMT-0500 (Eastern Standard Time): Adding "Follower/Wardrobe/Unknown" file: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAJacket.cr209:04:24 GMT-0500 (Eastern Standard Time): Adding "Follower/Wardrobe/Unknown" file: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAPants.cr209:04:25 GMT-0500 (Eastern Standard Time): Adding "Follower/Wardrobe/Unknown" file: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAShirt.cr209:04:25 GMT-0500 (Eastern Standard Time): Adding "Follower/Wardrobe/Unknown" file: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPASkirt.cr209:04:31 GMT-0500 (Eastern Standard Time): Executing Script09:04:31 GMT-0500 (Eastern Standard Time): Selecting Preset: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STAHat.cr209:04:31 GMT-0500 (Eastern Standard Time): Input Filename does not have "clothing" in its path: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STAHat.cr209:04:31 GMT-0500 (Eastern Standard Time): Input Filename does not have "accessories" in its path: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STAHat.cr209:04:31 GMT-0500 (Eastern Standard Time): Found alternate root directory "Character"09:04:31 GMT-0500 (Eastern Standard Time): Converting clothing from D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STAHat.cr2 to C:/Users/xboxl/Dropbox/3D/Content/People/Genesis 8 Female/Clothing/Converted/B25SteamPunk/B25STAHat.duf09:04:32 GMT-0500 (Eastern Standard Time): B25STAHat (Unknown) is not a clothing item of Follower/Wardrobe,Follower/Accessory09:04:33 GMT-0500 (Eastern Standard Time): Selecting Preset: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPABoots.cr209:04:33 GMT-0500 (Eastern Standard Time): Input Filename does not have "clothing" in its path: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPABoots.cr209:04:33 GMT-0500 (Eastern Standard Time): Input Filename does not have "accessories" in its path: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPABoots.cr209:04:33 GMT-0500 (Eastern Standard Time): Found alternate root directory "Character"09:04:33 GMT-0500 (Eastern Standard Time): Converting clothing from D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPABoots.cr2 to C:/Users/xboxl/Dropbox/3D/Content/People/Genesis 8 Female/Clothing/Converted/B25SteamPunk/B25STPABoots.duf09:04:33 GMT-0500 (Eastern Standard Time): B25STPABoots (Unknown) is not a clothing item of Follower/Wardrobe,Follower/Accessory09:04:34 GMT-0500 (Eastern Standard Time): Selecting Preset: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPACorset.cr209:04:34 GMT-0500 (Eastern Standard Time): Input Filename does not have "clothing" in its path: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPACorset.cr209:04:34 GMT-0500 (Eastern Standard Time): Input Filename does not have "accessories" in its path: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPACorset.cr209:04:34 GMT-0500 (Eastern Standard Time): Found alternate root directory "Character"09:04:34 GMT-0500 (Eastern Standard Time): Converting clothing from D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPACorset.cr2 to C:/Users/xboxl/Dropbox/3D/Content/People/Genesis 8 Female/Clothing/Converted/B25SteamPunk/B25STPACorset.duf09:04:35 GMT-0500 (Eastern Standard Time): B25STPACorset (Unknown) is not a clothing item of Follower/Wardrobe,Follower/Accessory09:04:35 GMT-0500 (Eastern Standard Time): Selecting Preset: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAJacket.cr209:04:35 GMT-0500 (Eastern Standard Time): Input Filename does not have "clothing" in its path: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAJacket.cr209:04:35 GMT-0500 (Eastern Standard Time): Input Filename does not have "accessories" in its path: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAJacket.cr209:04:35 GMT-0500 (Eastern Standard Time): Found alternate root directory "Character"09:04:35 GMT-0500 (Eastern Standard Time): Converting clothing from D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAJacket.cr2 to C:/Users/xboxl/Dropbox/3D/Content/People/Genesis 8 Female/Clothing/Converted/B25SteamPunk/B25STPAJacket.duf09:04:36 GMT-0500 (Eastern Standard Time): B25STPAJacket (Unknown) is not a clothing item of Follower/Wardrobe,Follower/Accessory09:04:37 GMT-0500 (Eastern Standard Time): Selecting Preset: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAPants.cr209:04:37 GMT-0500 (Eastern Standard Time): Input Filename does not have "clothing" in its path: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAPants.cr209:04:37 GMT-0500 (Eastern Standard Time): Input Filename does not have "accessories" in its path: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAPants.cr209:04:37 GMT-0500 (Eastern Standard Time): Found alternate root directory "Character"09:04:37 GMT-0500 (Eastern Standard Time): Converting clothing from D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAPants.cr2 to C:/Users/xboxl/Dropbox/3D/Content/People/Genesis 8 Female/Clothing/Converted/B25SteamPunk/B25STPAPants.duf09:04:38 GMT-0500 (Eastern Standard Time): B25STPAPants (Unknown) is not a clothing item of Follower/Wardrobe,Follower/Accessory09:04:39 GMT-0500 (Eastern Standard Time): Selecting Preset: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAShirt.cr209:04:39 GMT-0500 (Eastern Standard Time): Input Filename does not have "clothing" in its path: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAShirt.cr209:04:39 GMT-0500 (Eastern Standard Time): Input Filename does not have "accessories" in its path: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAShirt.cr209:04:39 GMT-0500 (Eastern Standard Time): Found alternate root directory "Character"09:04:39 GMT-0500 (Eastern Standard Time): Converting clothing from D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPAShirt.cr2 to C:/Users/xboxl/Dropbox/3D/Content/People/Genesis 8 Female/Clothing/Converted/B25SteamPunk/B25STPAShirt.duf09:04:40 GMT-0500 (Eastern Standard Time): B25STPAShirt (Unknown) is not a clothing item of Follower/Wardrobe,Follower/Accessory09:04:40 GMT-0500 (Eastern Standard Time): Selecting Preset: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPASkirt.cr209:04:40 GMT-0500 (Eastern Standard Time): Input Filename does not have "clothing" in its path: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPASkirt.cr209:04:40 GMT-0500 (Eastern Standard Time): Input Filename does not have "accessories" in its path: D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPASkirt.cr209:04:40 GMT-0500 (Eastern Standard Time): Found alternate root directory "Character"09:04:40 GMT-0500 (Eastern Standard Time): Converting clothing from D:\DAZStudio\DAZ\Content\Runtime\Libraries\Character\B25SteamPunk\B25STPASkirt.cr2 to C:/Users/xboxl/Dropbox/3D/Content/People/Genesis 8 Female/Clothing/Converted/B25SteamPunk/B25STPASkirt.duf09:04:41 GMT-0500 (Eastern Standard Time): B25STPASkirt (Unknown) is not a clothing item of Follower/Wardrobe,Follower/Accessory09:04:41 GMT-0500 (Eastern Standard Time): Execution Complete.
PS: I also seem to have the same problem as @FSMCDesigns , only force convert works. I've tried to convert 1 item in this log file without force convert.
Thanks for sharing @dkgoose!
You're welcome!
thanks for showing these converts @dkgoose they look really good!
No problem :), I’m still working on converting clothes too :)
This converter is a great achievement - thanks a lot for make it happen.
Below is a render of converted Extravaganza II dress by Powerage on Rochelle
https://www.daz3d.com/fwsa-rochelle-hd-for-genesis-8-female
Wow, that is a gorgeous dress.
Any idea why it's not converting any items?
That is great to hear!
I was wondering if Sock items should be converted with the Footwear option rather than the Item option?
I dont see any difference but I'm new to the converters.
So this is G8F with V4 Elaia Dress,her own shoes and jewelry but she so happy
13:25:10 GMT+0100 (Mitteleuropäische Zeit): Adding DirectoryB:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age
13:25:11 GMT+0100 (Mitteleuropäische Zeit): Adding "Follower/Wardrobe/Unknown" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/ExtraLongGloves/ExtraLongGloves.cr2
13:25:11 GMT+0100 (Mitteleuropäische Zeit): SKIPPING "" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/Karate Outfit/!Top.cr2
13:25:12 GMT+0100 (Mitteleuropäische Zeit): SKIPPING "" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/Karate Outfit/!Trousers.cr2
13:25:12 GMT+0100 (Mitteleuropäische Zeit): SKIPPING "" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/Karate Outfit/Belt.cr2
13:25:12 GMT+0100 (Mitteleuropäische Zeit): SKIPPING "" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/Maid/Apron.cr2
13:25:13 GMT+0100 (Mitteleuropäische Zeit): SKIPPING "" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/Maid/Bra.cr2
13:25:13 GMT+0100 (Mitteleuropäische Zeit): SKIPPING "" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/Maid/Hat.cr2
13:25:13 GMT+0100 (Mitteleuropäische Zeit): SKIPPING "" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/Maid/Panty.cr2
13:25:13 GMT+0100 (Mitteleuropäische Zeit): SKIPPING "" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/Sexy Baby IV/Short.cr2
13:25:14 GMT+0100 (Mitteleuropäische Zeit): SKIPPING "" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/Sexy Baby IV/Top.cr2
13:25:14 GMT+0100 (Mitteleuropäische Zeit): Adding "Follower/Wardrobe/Unknown" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/Small Lovely XIII/Small Lovely XIII.cr2
13:25:15 GMT+0100 (Mitteleuropäische Zeit): Adding "Follower/Wardrobe/Unknown" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/Strapless Bra Set/Bra.cr2
13:25:15 GMT+0100 (Mitteleuropäische Zeit): Adding "Follower/Wardrobe/Unknown" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/Strapless Bra Set/Panty.cr2
13:25:16 GMT+0100 (Mitteleuropäische Zeit): SKIPPING "" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/Tiny Bikini III/Tiny Bikini III.cr2
13:25:16 GMT+0100 (Mitteleuropäische Zeit): SKIPPING "" file: B:/DAZ3D Content/Content/Runtime/Libraries/Character/3D-Age/Tiny Bikini IV/Tiny Bikini IV.cr2
No, you shouldn't need it for socks.
Huh. Can you make sure output_debug = true in the Data/RiverSoft Art/Common/RSCCConstants.dsa and post the Daz log?
You can just add them using Add Files too.
.Its set to true and this came out:
