The Gothic Library
Michael L RogersMichael L Rogers Posts: 141
edited January 2019 in Daz Studio Discussion
Just a question to anyone that's understands what I can do to get the noise or grit out of my image and look clean like the promo image from "The Gothic Library". I've done no touchup to my image. Rendered as is from promo render settings from product. After this first render, I did try and change different settings like rendering quality, max samples and max time. But to no avail.
It's camera 8 and render settings 8.
Post edited by Michael L Rogers on
  • nicsttnicstt Posts: 11,715
    Render it much, much, much longer.
    Add more light, then use tone-mapping to adjust how it looks
  • Ok, thanks nicstt
    Ok, thanks nicstt
    You could file a ticket, asking for what settings were used to create the promo.
  • Oh ok, great.
  • The render settings file, if you applied it, should be what was in the promos. My best guess would also be too just set the maximum time higher. Most of the vendors presets have a maximum time of around an hour I have noticed, I usually set that to around 2 hours, just because I'm not much more patient than that. Also worth checking how it looks without an added figure after an hour. If the image size is enough to put you over the limit of your graphics card, that could slow it down significantly.
  • Yeah, I’m now sure that, that it the  situation. My graphic card is probably not powerful enough so I need to allow for far more rendering time. And you’re right the objects probably completely change the lighting from the actual promo picture. thank you.
