obj/obp riles
goofygrmom3
I just purchased the hay bales and can't remember how to open an obp file. I'm having a senior moment. Please help. Thanks.
goofygrmom3
Import it using your object preset library (THe little arrow next to "Create" on the top line of icons
You can add a category by clicking the plus sign at the bottom and adding your own folder,
An OBJ can be imported using the File import command from the left hand drop down menu, but it is better to use an OBP when one is available as that has the materials all set up in the file.
If you put a folder with .obp files in it into the Bryce Objects presets folder, then those .obp libraries will appear within that folder in the Create menu list the next time you run Bryce.
For example, I have a folder called "sean objects" where I keep all my .obp files that aren't already put there by installers, and when I set up my Windows 7 pc, I just copy that folder to "C:\Program Files (x86)\DAZ 3D\Bryce7\Presets\Objects", and all my .obp's are then instantly ready to use in Bryce.
Thanks for the info. I've saved the screen shots, too. I should be able to handle this now.
