[Released] Hair Converter from Genesis 3 Male to Genesis 8 Male [Commercial]
2»
  • carrie58 said:
    ohhhhsad   ..........soon?angel
    Soon!
  • carrie58carrie58 Posts: 4,102
    Cool!!
    laugh
  • RiverSoft ArtRiverSoft Art Posts: 6,816
    edited January 2019
    carrie58 said:
    Now ?
    Now!  It is released.
    Post edited by RiverSoft Art on
    YEAH!!!!
  • carrie58 said:
    YEAH!!!!
    laugh
  • DaikatanaDaikatana Posts: 830
    YES!!!   Just picked this one up.  Thank you so much for continuing to make these wonderfully useful conversion products!
    You're very welcome!  Thanks for the support!
  • I've tried this a few times with various restarts, but I get this error with G8M selected in my log:
    2019-01-21 00:05:55.467 Loading script: D:/My DAZ 3D Library/Scripts/RiverSoft Art/Hair Converter/Hair Converter G3M to G8M.dse
    2019-01-21 00:05:55.493 DEBUG: Found: D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSConstants.dsa
    2019-01-21 00:05:55.507 DEBUG: Found: D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSHairConstants.dsa
    2019-01-21 00:05:55.517 DEBUG: Found: D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSBuildPanels.dsa
    2019-01-21 00:05:55.529 DEBUG: Found: D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSHelperFunctions.dse
    2019-01-21 00:05:55.541 DEBUG: Found: D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSAssemblyLineFunctions.dse
    2019-01-21 00:05:55.561 DEBUG: Found: D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSConversionFunctions.dse
    2019-01-21 00:05:55.581 DEBUG: Found: D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSHairConversionFunctions.dse
    2019-01-21 00:05:55.608 WARNING: Script Error: Line 176
    2019-01-21 00:05:55.609 WARNING: ReferenceError: Can't find variable: GenesisGeneration
    2019-01-21 00:05:55.609 WARNING: Stack Trace:
    <anonymous>()@D:/My DAZ 3D Library/Scripts/RiverSoft Art/Hair Converter/Hair Converter G3M to G8M.dse:176
    2019-01-21 00:05:55.612 Error in script execution: D:/My DAZ 3D Library/Scripts/RiverSoft Art/Hair Converter/Hair Converter G3M to G8M.dse
  • missuskissesmissuskisses Posts: 918
    edited January 2019
    I got some updates installed today, and now it looks like the G3F to G8F hair converter doesn't work for me either (it previously did).
    2019-01-21 00:19:35.979 Loading script: D:/My DAZ 3D Library/Scripts/RiverSoft Art/Hair Converter/Hair Converter G3F to G8F.dse
    2019-01-21 00:19:36.209 DEBUG: Found: D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSConstants.dsa
    2019-01-21 00:19:36.236 DEBUG: Found: D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSHairConstants.dsa
    2019-01-21 00:19:36.256 DEBUG: Found: D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSBuildPanels.dsa
    2019-01-21 00:19:36.286 DEBUG: Found: D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSHelperFunctions.dse
    2019-01-21 00:19:36.325 DEBUG: Found: D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSAssemblyLineFunctions.dse
    2019-01-21 00:19:36.360 DEBUG: Found: D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSConversionFunctions.dse
    2019-01-21 00:19:36.396 DEBUG: Found: D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSHairConversionFunctions.dse
    2019-01-21 00:19:36.440 WARNING: Script Error: Line 177
    2019-01-21 00:19:36.440 WARNING: ReferenceError: Can't find variable: GenesisGeneration
    2019-01-21 00:19:36.440 WARNING: Stack Trace:
    <anonymous>()@D:/My DAZ 3D Library/Scripts/RiverSoft Art/Hair Converter/Hair Converter G3F to G8F.dse:177
    2019-01-21 00:19:36.456 Error in script execution: D:/My DAZ 3D Library/Scripts/RiverSoft Art/Hair Converter/Hair Converter G3F to G8F.dse
    Post edited by missuskisses on
  • I got some updates installed today, and now it looks like the G3F to G8F hair converter doesn't work for me either (it previously did).
    That is strange.  GenesisGeneration is located in D:/My DAZ 3D Library/data/RiverSoft Art/Common/RSHelperFunctions.dse, which it found.  What changed on your system?
    I don't think I changed anything? I know there were lots of updates today for your scripts, which I downloaded. But I hadn't tried the converter products in a few weeks.
    Yeah, I copied over the fixed Foot Poser dialog (from the upcoming Clothing Converter V4->G8F) and the improved Daz clothing item search (from the Hair Converter G3F->G8F) to all the converter scripts.  That should not have affected this.
    Are the new updates working for others?
  • I just installed G8M and the hair converter script only to a second computer. No problems. So...it's gonna suck trying to figure out why it won't work on my main rendering comp.
    Huh.  Sorry for the inconvenience, but I am glad you got it working.
  • MouserMouser Posts: 675
    Not sure why this is happening as the Female hair converter worked fine.
    The male hair converter is getting the Y translate wrong as the convertered hair is located in the middle of the figures head.
    Anyone else running into this issue?
    Log shows no errors.
    Bizarre.  Anyone else seeing this problem?  Have you restarted Daz and tried again?
  • Kev914Kev914 Posts: 1,127
    Worked OK for me. I converted all the Hairs that were in the Hair folder under Genesis 3 Male. I have several of the converters but this is the first one I actually tried to run. I read through the pdf first and then I just gave it a go. I kept the defaults and just selected the folders I wanted to convert and told it where to pu them. While it was running, there were times that the panel disappeared, and then it would come back. I also saw that the hair was above G8 Male in the scene. But after it was done, I tried using several of the hairs and they all worked perfectly. Now it's on to the clothes.
    Excellent!  Thanks for sharing.
    Yes, occasionally, the panel will disappear.  This is because the script is working hard and starving the GUI refreshes of clock cycles.  Eventually, there is a GUI update and you see it again.  This is normal behavior.
    Okay I have restarted the PC and deleted the existing converted hair files.
    Used M8 & converted Genesis 3 Male Hair directory.
    Same result?
    Picture attached
    335 x 404 - 23K
    Same result?
    Picture attached
    Huh.  Is this for all converted hair?
    edited January 2019
    Does it matter if you use M8 or Genesis 8 Male? Are they considered the same? I think the pdf said to load Genesis 8 Male, so that is what I used.
    I see Mouser used M8.
    Post edited by Kev914 on
    edited January 2019
    Looks like your correct, most of the hair files convert with the default Genesis 8 figure.
    Though one (Cage Casual Waves) still doesnt all of the rest convert okay.
    My DS setup was for V8 or M8 by default and the other converters worked with characters just fine.
    But this works, thanks;)
    Post edited by Mouser on
    Wow, nice catch @KevinH.  I thought the M8 was just for showing the hair, not the conversion.
    Yes, you must always use the plain vanilla G8M or G8F.
  • DkgooseDkgoose Posts: 1,451
    Has anyone tried converting any of RedzStudio hair, I tried converting his executive hair but it won’t convert, maybe because of how it’s made?
    I tried converting the Vintage Male Hair , had to unparent all the parts and save them seperately ,
    Yes, that is correct.
