Installed Morph Products Not Showing In Shaping Tab
Hi, I recently purchased the Ethnicity for Genesis bundle https://www.daz3d.com/ethnicity-for-genesis-bundle and installed it using the DIM (see attachments). However when opening DS and adding a Genesis 2 Male, the morphs do not appear in the shaping tab (I tried all the other Genesis characters too). I then tried installing the files manually through the My Daz Studio Library folder (see attachments), without any success. I have also tried going to "Content Database Maintenance" and "Re-Import Metadata", however the product does not appear on that list (see attachments).
This is the first time I have had to post on forums for anything like this, it would be great if I could get some help.
Thanks
  • NorthOf45NorthOf45 Posts: 5,764
    Um-m, that will only work on Genesis (Generation 5 characters like Victoria 5 and Michael 5), not Genesis 2...
  • TZORGTZORG Posts: 148
    If you load a Genesis 1 and look under head?
    1306 x 609 - 97K
  • Cheers guys, everything works great now :)
