changing content drive
Hiya!
My internal hard drive filled so I am attemptiing to move my entire library to an external drive
I opened DIM and under PORTABLE DRIVE naviagted to my drive and the folder 3D CONTENT
In the preferences tab in DAZ, I selected the same drive.
I'm missing a step somewhere.  DAZ can't locate my files    HALP
  • tophandtophand Posts: 136
    OOPS   line 2 should read D:DAZ3D.   Tried several times. Missed that edit
  • Have you told DIM to use that new path? It doesn't look like it, sicne the ... button for the Recommended path (used to edit) is still greyed out. And did you move your existing content to the new location? You will also want to chnage the option for updates, above the folder ,ist in DIM, to Install to Selected path (otherwise any updates will install all their files to the original C: drive location).
    thank you!
