Smart Content (Solved)
Noah LGP
Hi,
For some mysterious reasons, Smart Content tab refuse to display the short hair of Stylish Shaved Hair and the destroyed library of i13 Library Environment , I must browse in the Mapped Folder of the Content Library tab.
If I try to add manually this content to the products, nothing happens it's never in the Smart Content tab.
I also tried to uninstall/reinstall with DIM.
Post edited by Noah LGP on
Smart Content requires that a compatibility be set. For the Shaved Hair you can do that by dragging into the appropriate category in Smart Content with Genesis 8 male or Genesis 3 male loaded and selected (using the hair for that figure).
Stylish Shaved Hair is in Lost and Found / Stylish Shaved Hair by default, I replaced it by Hair / Short but it's still missing.
Drag it from "Content Library" to "Smart Content", exactly in the category you want to, while the figure is selected. If you want to see it in short, drag exactly on the "short" entry.
I need more instructions because I can't drag the hair from the Mapped Folder to Smart Content tab.
Load the figure - geensis 8 Male or Genesis 3 Male - and select it. The drag the icon for the matching hair (it has versions for both) across to Smart Content.
This action is still forbidden for both tabs (Files and Products)
Files rather than products. Please post a screen shot of what you have before dragging and trying to drop.
Here the screenshot
I can't really read that, but where is your content Library pane to drag from?
Content Library tab is the next after Smart Content tab.
https://i22.servimg.com/u/f22/15/54/71/55/smart_11.jpg
So how are you dragging from the Content Library pane to the SMart Content pane?
I go in Mapped Folder and drag the hair thumbnail (wearable preset) over the Smart Content tab.
Does that cause the pane to pop up? Even if it does, try doing it with both visible at once - and drop in a category.
That's why I've specified NOT on the tab, but on its menu (where it's written poses, figures, wardrobe...)! ^^
Just put smart content on the right, content library at the left, and drag the files. In files mod, not product!
The screenshot is unreadable.
Both panes are visible. This action is still forbidden...
Anyway, I created a Custom Action, it will be a good shortcut.
The thumbnail doesn't havea content type tag at top-right, which suggests it may not be in the database at all.
Well, I installed it again with Daz Connect this time, now it's repaired, Lost and Found was added.
DIM isn't always a reliable source.
