Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Iray needs an Nvidia GPU If you want to use Iray in the furture you would be better getting a machine that will support Nvidia cards, so Intel rather than AMD.
Regarding the SSD. I would personally go with a 3.5 inch SSD rather than an M.2. There is a 250GB Samsung 860 EVO under the "1st Storage Drive" on the configuration page. I'd advise this as the M.2 drive can use up the resources needed for one of the PCI-E slots on the motherboard, and if you need to replace it in the future, you will find it a lot easier to clone your C: drive to a new SSD than to an M.2 drive.
I actually always run AMD machines, but then I don't actually use DS. and if I did ever decide to use DS it would only be as a plug in for my main program, not to render in. I Use Bryce.
I'm going to have to admit that was a bad suggestion on my part as it would involve you upgrading the CPU yourself later and selling on the initial CPU. Hassle I don't think you're after.
CPU: Intel Core i9 Eight Core Processor i9-9900k (3.6GHz) 16mb cache.
Max Turbo Speed on the i9 is 5.0 GHZ so its 3.6 - 5.0.
As far as I am aware Nvidia GPU will run just fine with an AMD processor. What you need to avoid when using Iray is a AMD graphics card, not an AMD processor.
I Personally think it looks beautiful. Excellent choice for a CPU cooler, Noctua is the best cpu cooler on the market based on my research. Thats the cooler I was looking at for my next computer build as well.
I've not bought a sound card since the 90's. Its an easy decision though - you can just get one later.
You have a 1200W PSU in there so I assume you are intending to put a 2nd graphics card in the machine later [because thats the only reason bar nitrogen level overclocking you would ever have a 1200W PSU].
With a 2nd graphics card you will have to check whether you have space for 3 extra PCI cards that you have listed. People often end up having to ditch their sound cards to accomodate 2 graphics cards.
Hi Xtro,
I have to agree with Bk007dragon - that is indeed a thing of beauty. Looks like it will serve you well for many years because it has some easy upgrade options for the future such as a second gfx card.
As far as the sound card goes, I also agree with jmtbank. I think the last computer that I had with a sound card was a Pentium IV. These days the on-board sound is good enough for anyone except musicians. I'd stick with the on-board sound and save the slots on your motherboard for other expansions later.
Good to hear about the 1070ti being back in stock.
It does; I use Nvidia cards on AMD Threadripper.
Launch Install manager but instead of entering your password select Work Offline - you can then configure its paths before starting to download.
I wouldn't disagree with Richard's answer above on how to start this as he is the expert on these things.
As for where to install, I would do as you mentioned - put Daz3D on the C: drive and set the path for your content on one of the HDDs.
Great looking machine, and very nice specs. I hope it serves you well for many years to come.
The problem with the second harddrive is the same problem I had with my build from PCspecialist and with the same case it seems its a bit of a problem with that case.
cheers finally got it sorted by reading some old post on this subject. so far things seem to work. :)
just finished my daz install on C and put my backup runtime fils on D drive. looking good so far, just need to have a good play around inside Daz Studio to see if everything is running correctly. im definitely impressed with the new build. My old PC that i was using Daz3d on, might as well of been a Potato. This new build is miles ahead for me and i hope i also get many years of use out of this machine. :)
Funny enough the day before my new PC came, i was watching Youtube on someone who was unboxing his new pc from PCspecialist who also had the same case and he also had the same problem with his 2nd harddrive not showing.
Don't get the 9900K. At the price they ask, you might as well go Threadripper.
too late now ;)
however one of the reasons i picked Intel over AMD was because of other non related Daz3d programs i want to do on my pc.
